MAP charge pipes?
Chesapeake
As far as I remember when I was shopping around, they weren't that cheap, I think they used to be $299 plus shipping so I would say jump on them if it's for both the hot and cold pipe and the cold pipe replaces the entire stock one.
Los Angeles
I have them. Sound great and seem nice but I did recently find a cracked area around the mounting flange that I had to reweld.
This seems to be a common issue with alot of the pipes is it breaks right at the mounting tab....there must be another route for pipes.
S
Ravenna
Do you have a RMM installed? Seems to be a common problem with all of the charge pipes out there. Cobb supposedly said with a RMM installed it shouldn't be an issue. Thoughts?
I have a Boomba RMM installed yes....i don't foresee that being an issue...
alexrex20
Spring
If you're not BT, save your dineros
