Ford Fiesta ST (FMIC) Front Mount Intercooler Kit
The COBB Ford Fiesta ST FMIC system is the single best bolt-on modification for the platform, allowing for much cooler boosted air temps that respond with healthy power increase when tuned with an Accessport.
Replacing the factory plastic tubing with 2.5" mandrel bent piping, the COBB Fiesta ST Hard Pipe Kit removes restriction and improves airflow to the engine of your Fiesta ST. The COBB Fiesta ST Hard Pipe Kit consists of single piece pipes made from mandrel bent aluminum tubing on both the cold side and hot side of the intercooler. The results are weld-free pipes from the turbo outlet to intercooler inlet and from the intercooler outlet to the throttle body. COBB silicone hose couplings and heavy duty T-Bolt hose clamps finish off this kit and ensure the pipes stay put.
Features:
- 2.5" Mandrel Bent Aluminum Tubing
- 4-Ply Silicone Couplers
- Powdercoated Wrinkle Black
- Works with Stock or COBB Intercooler
- Increased Air Flow
Ford Fiesta ST Intercooler Upgrade
The COBB Fiesta ST Intercooler Upgrade is a direct replacement of the factory piece and is the easiest modification to make for a drastic increase in cooling and power. Includes everything needed to install and requires no bumper modifications.
The COBB Fiesta ST Intercooler Upgrade is the easiest way to drastically improve power when coupled with tuning from the Accessport. Even when stock, the factory FMIC can be overwhelmed with heatsoak. By using a 55% larger core, your Fiesta ST will come alive with the new found colder charge air. This upgrade requires no modification to the car for an easy installation. Factory-like fitment for the Fiesta ST.
Features:
- Custom Cast Endtanks with COBB Logo
- 27.5" x 6" x 3" Bar and Plate Core
- No Cutting or Drilling Required
- Works with Stock or COBB Piping
- Increased Cooling Efficiency
Ford Fiesta ST Hard Pipe Kit
The COBB Fiesta ST Hard Pipe Kit allows the use of the factory or COBB intercooler core while cleaning up the engine bay and freeing up airflow to the engine.
Features:
Thanks for looking! Availability will be somewhat limited when parts first come out (like with any new parts on the market), so keep that in mind when ordering, but contact me directly with any further inquiries
