- Member ID
- #596
- Messages
- 345
- Likes
- 38
Hey guys! Here to introduce a new product for you to see. Want more power from your turbocharged car? Safely increase boost and make more power with the Turbo Transformer Performance Module! The Turbo Transformer is a true Piggy-Back type device that installs between your OEM MAF sensor and does not alter the MAF sensor signal output until boost exceeds 12PSI. The Turbo transformer alters the signal to boost sensor output after the intercooler, so your ECU sees the extra boost on the MAP sensor and subsequently calls for the appropriate target lambda and spark, providing a safe increase in power and boost.
The Turbo Transformer is a true Piggy-Back type device that installs between your OEM MAF sensor and the factory wiring harness, with no cutting or splicing involved. Featuring a Atmel ATMEGA328PU Microcontroller, the Turbo Transformer is an intelligent device that does not alter the MAF sensor signal output until boost exceeds 12PSI. The Turbo transformer alters the signal to boost sensor output after the intercooler that has nothing to do with fuel control. Your ECU sees the extra boost on the MAP sensor and subsequently calls for the appropriate target lambda and spark.
[video=youtube;RCLkcV7xxxI]http://www.youtube.com/watch?v=RCLkcV7xxxI[/video]
Developed by a Software Engineer from one of the most respected tuning houses for BMWs up in the Bay Area, the Turbo Transformer offers a nice increase in power at a very reasonable price point. Featuring proprietary code developed by this engineer, the Micro-Controller increases overall boost pressure safely to yield an increase of approximately 20-25whp & 20-25wtq on Ford Fiesta ST.
[video=youtube;zIVYOlaQfrE]http://www.youtube.com/watch?v=zIVYOlaQfrE[/video]
Will the Turbo Transformer Lean out my engine?
NO! All EcoBoost engines feature a factory wideband O2 sensor that works in concert with the MAP sensor. The Turbo transformer alters the signal to boost sensor output after the intercooler that has nothing to do with fuel control. Your ECU sees the extra boost on the MAP sensor and subsequently calls for the appropriate target lambda and spark, verified by extensive data logs. Click here for STOCK Focus ST Datalog; Click here for Turbo Transformer Focus ST datalog.
Turbo Transformer Performance Module 2013+ Ford Focus ST; Fiesta ST + sFe & EcoBoost Fords
If you have any questions, don't hesitate to ask, or feel free to send me a PM/Email or simply call at 714.582.3330 extension 8002, or ask for Jurrian
