O2 sensor replacement
FiestaSTdude
Cary, NC
So I'm nearing 100k and I've noticed people recommend replacing the O2 sensors at 75k. Oops. Anyway, I'm not sure where they are located on the car. Does anyone have a video showing how to/where to install them?
Melbourne
Oh shit.. I'm over 112000km now.. I'd like to know also..
Saint Pauly
Both can be easily accessed from under the car....upstream is before the catalytic converter in the Dp and the downstream is after the catalytic converter. Get an O2 sensor socket also....dont use a normal socket....its the garage hack way that can damage o2 sensor wires. Buy the sensors from Rock Auto* not a parts store..Buy Motorocraft or Denso...save a nice amount of coin also.
FiestaSTdude
FiestaSTdude
Cary, NC
Thanks TyphoonFiST!
Minnesota
I just got a P0137 CEL, so looks like I will be doing this at 50k instead of 75k.
@Salty_FiST
Active Duty U.S. Air Force
Crestview Florida
What size O2 sensor socket is needed?
Sent from my SM-S908U using Tapatalk
@Salty_FiST
Crestview Florida
San Diego
Good, and good luck!
I had a really hard time trying to remove the downstream sensor as it was seized.
Saint Pauly
Get this one.....The other chrome style sockets will start to bend and strip where the o2 wiring comes through if you really reef on a stuck Sensor. i suggest getting an hardened impact style one as they hold up better and last longer.
Amazon.com: 10Pcs O2 Sensor Socket-Oxygen Sensor Socket Removal Tool with 10mm/3/8in Square Hole and 22mm/7.8in 6 Point Socket, Oil Pressure Sending Unit Drive Impact Socket Adapter : Tools & Home Improvement
Mpumalanga
So I'm not clued up here, why not use a spanner to open the sensor
Sent from my SM-G991B using Tapatalk
Kalamazoo, MI, USA
I don't know about South Africa, but corrosion on exhaust bits can be exceedingly bad here in the United States. Having more of the bolt head engaged keeps it from rounding off. If you had a 22mm line wrench that would work too. I can't remember but I don't think a box end wrench clears over the plastic connector, but if you were committed to the sensor replacement you could cut the harness off and use a box end or normal deep socket.
@Salty_FiST
Crestview Florida
Get this one.....The other chrome style sockets will start to bend and strip where the o2 wiring comes through if you really reef on a stuck Sensor. i suggest getting an hardened impact style one as thye hold up better and last longer.
Already got the one I linked of Amazon and YouTube. I'll check it out though!
Alicepl
Polska
Hello, I have a Fiesta USA but not an ST, I am looking for the cause of the P0137 code, please tell me which sensor to replace? Can I get the product code? I read that you need a cap to unscrew it. I had the catalytic converter and probes replaced. The problem is still there. Where else can I look for the cause? In Poland, mechanics cannot find the cause...
pixelzombie
Chicago, IL, USA
that item is no longer available, I'm assuming this one will work just as well: Oxygen Sensor Socket
Also, has anyone had luck using a sensor cleaner that you put into the gas tank?
GA
FWIW, I have a set made from chrome vanadium and they have worked just fine.
