Oil Catch Can Comparo Thread
Which OCC did you install?
  • Mishimoto
    Votes: 49 30.6%
  • Boomba
    Votes: 9 5.6%
  • James Barone Racing
    Votes: 3 1.9%
  • Damond Motorsports
    Votes: 71 44.4%
  • "Custom"
    Votes: 10 6.3%
  • Other
    Votes: 18 11.3%
  • Total voters
    160
Saint Pauly
Then you must be vigilant and check back often....or slip the counter guy in a grey shirt a Abraham Lincoln and Tele number to keep you Informed...
Grubbenvorst
So me being me, i thought it would be wise run ahead of things and order the Damond Motorsports OCC before taking delivery of my 2014 (EU) FiST. Now I found out the EU FiST (or at least mine) does not have the weld stud in the engine compartment! Buyers be aware [}(]
Saint Pauly
Make your own....drill a hole or utilize a self tapping screw....
Grubbenvorst
That would mean removing the RH shock assembly + taking the neccesary precautions to avoid corrosion... The whole point was having a plug&play solution. I would rather cut the PCV tubing and install a boomba OCC instead, but I have to wait for my CPE parts.
College Station
So do our Fiestas have a large amount of oil blow by to warrant the OCC? Or is it more of a looks thing? A friend of mine with a Hellcat has one and it collects a good amount of oil so I was just wondering how bad it was on the FiST.
So Cal
Not a looks thing. FiST's are direct injection meaning no fuel is cleaning the intake valves so you want to keep as much PCV oil / gasses away from them as possible.
It also helps with the prevention of the combustion mixture's octane rating being lowered slightly by those same said blow-by gasses/oil vapors.
Saint Pauly
What is the "VTA kit" that comes with the Damon kit? Do I need it?
It stands for Vent To Atmosphere...I don't have it...I have the oil cap that vents to atmosphere...a very tasty piece I might add...everything helps.
Hennepin
On my Mishimoto I have a drain valve installed with a 5/8" hose attached that runs down to the bottom of the engine bay and sticks out of the rock guard through a drilled hole. Easy to access and easy to install that drain. Every few thousand miles I just turn the lever for a minute and then close it up again. The mounting bracket allows for plenty of room to do this. I would post pictures if I had some
Dublin, OH
The Damon OCC comes with a drain valve already installed and it also comes with the length of hose to run to the bottom of the car. It also includes a check valve Installed in the correct hose and in the proper direction and OEM fittings that are correct for the year of your FiST so you do not have to cut your current vent line to get the fittings.
^^^ALL of the above, plus where, and the way it is mounted are WHY I chose it over all of the others. [wink] [:)]
REALLY EASY and SOLID install! [thumb]
Saint Pauly
Agreed 100% here...the only thing I wish they'd have done is having The hose sleeves when i purchased mine....I've got them now though...
felopr
JD
I have the damond motorsport catch can with VTA kit, i find it the best out of all the catch can that is sold as a kit for our cars.
Comes with correct way measurement for the hoses both ways, has a check valve in the correct hose and in the correct way.
Diferent color hoses, also a hose sleeve for peace of mind. VTA option has a check valve also. it truly is a plug and play system and the most complete of them all.
The only minor setback is the drain valve, not that is bad but, but if you dont remove the catch can, is very dificult to get to it and open it, someone with big hands or someone with a full intake might have to remove the catch can to open the valve
Saint Pauly
This is what my Gfs son is for...small hands and arms. Works great...now only if I could get him to join the circus in the summer time...so I can be free again to do as I please.
felopr
JD
i have small hands also but yeah is a bitch to get to with a cobb cai in the way
Dublin, OH
Do catch cans even do anything. I've read that they are worthless
It's a subject of debate. My Damond does accumulate oil, so you be the judge. If you are skeptical, you'll have good company. For me it seems like cheap insurance if it helps reduce the documented carbon build-up on the intake valves.
