Oil shavings in drain pan after oil change
Huntington
The car only has about 24,000 miles on it, and this is the second time that this has happened since I've owned the car. Ive found easily visible, different size metal shavings in the oil drain pan. Anybody know what it could be?
C
Huntington
nope, just loose in the drainage pan. the drain plug wasn't marred or anything.
Raleigh
Could have been in the puck up screen from the last time you looked. If you're really concerned about tit, remove the pan and clean the pan and pick up good.
Shelton
If the car is still under warranty I would take it in and have them look at it. Is it making noise or smoking at all?
Wrenching for Ford is what I do
