P219A code appeared (“Bank 1 air fuel ratio imbalance”), with no noticeable symptoms. I used scan tool to pull diagnostics and noticed my fuel rail pressure was around 2000 psi. Quick search shows fuel rail pressures should be closer to 100 psi.
I cleaned the MAF sensor and cleared the code, drove for about 40 miles and the code has not reappeared, but the fuel rail pressure has not changed.
Any advice to resolve this issue? Is my fuel pressure really that high, or do I have a bad sensor? I’m not sure where to start in my troubleshooting approach.
Thanks in advance for any help.
