Saw this:
https://pumaspeed.co.uk/product-Fiesta-ST180-Quaife-10J-Sequential-Transmission_21414.jsp&pic=1
It's an adapted Honda gearbox:
https://shop.quaife.co.uk/shop/gearboxes/sequential/qbe10j/
Now discuss and order a bunch and set new speed records
PumaSpeed said:
Designed and manufacturered in-house at Quaife's facility in Kent, the QKE10J 6-speed sequential gearbox is the ultimate upgrade for your drivetrain.
Featuring Quaife manufactured alloy transmission casing, incorporates Quaife's state-of-the-art sequential gearchange meaning it's impossible to mis-shift with ultra-fast shifting. The design includes additional supports between gears 4 and 5 to strengthen the shaft, making a more efficient and robust gearbox, better suited for racing and rally use. All gears are straight cut.
Key technical features:
- Drum style shift mechanism for fast reliable gear changes
- Strengthened LM25 alloy outer casting
- 6 wider than standard gears for additional strength
- Open face dog engagement gears
- Ultra-fast Quaife sequential gearshift
- Choice of gear ratios and final drive
- Optional Quaife ATB differential
- New generation of gearchange mechanism allows fitment to front and rear wheel drive applications
- Compatible with flat-foot-shift systems
- Supplied with either a level and cable, or air actuator
- Includes oil temperature sensor
- Weighs 35kg
- Digital display and paddle shift ready
