Hey everyone, my radiator fan (I have a mountune radiator) has not been turning on for a while now and I’m finally getting around to solve it but 2 of the main problems I’ve found on the forum and subreddit haven’t fixed the problem. First I pulled the high speed fan relay and tested it with a multimeter and it seemed good. So then I ordered a new OEM fan shroud which is the only way you can get a new fan control module so I swapped it out and while doing so discovered that my old one didn’t have any signs of burnout on the contacts and to no surprise the new one didn’t fix the problem. My next thoughts are maybe the actual fan is bad and I should replace the whole shroud since I have the new one now anyways. My AP said fan actual and fan desired at 92% with the coolant temp at or above 200F and the fan wasn’t spinning.
Is there anything else I can test? Or should I just swap out the shroud and see if that fixes it?
Thank you in advance!
