Rear Motor Mount
Burlington, VT, USA
Hey Everyone,
I'm driving a 2019 FiST and will be doing a COBB Sage 1 tune next month.
Wondering if the stock RMM is adequate, or if I should go for the COBB RMM.
I read that they improved the stock RMM in 2016.
I could save $100 and just get the access port.
Thoughts?
Central CT
I highly recommend getting a RMM asap with a tune.
Which brand RMM? Everyone has their preference, but in the end they should all do the same thing.
Mikey456
Los Angeles
The Cobb Stage 1 adds more torque to the motor which would probably lead to more motor movement. That’s why its included in their “Stage 1”. I use a Mountune RMM. But any brand other than stock would be better. Just don’t get one that is too stiff because you with get more vibrations in the car.
S
Burlington, VT, USA
Okay, It sounds like good advice to upgrade, so I'll order the COBB Stage 1 package with the access port, RMM, and air filter. Thanks, guys for your input!
Brianmc27
Folsom, CA
Better idea - get a whoosh RMM and a RamAir filter from Whoosh. Get a Accessport from Dizzy with his stage 1 tune. Save money - get a better tune.
Mikey456
Los Angeles
Yes as he said above ^^^^. Check out what other forum members have done. Yes u need a RMM first. But if u buy a new Accessport, buy one with a tune included.. Or buy a used one.
2017 Ford Fiesta ST, Shadow Black, Recaro seats, Mountune RMM, Swift springs, 5mm rear spacers, Falken 615+ tires
Brooklyn
Hey Everyone,
Thoughts?
If you're happy with how it feels now then you probably don't need it. I suggest finding a used AP rather than going with the Cobb 'stages.' Drive with the revised AP map and if you feel you need a rmm then, you can try to get a used one - they're occassionally listed for sale on this forum.
DEss
S
Burlington, VT, USA
Thread Starter #13
Yeah, Ron at Whoosh is really cool. After discussing things a bit, I decided to go with the Vibra-Technics RMM, and RAMAIR air filter (he was out of stock on the Whoosh RMM). I found a local shop to do a pro-tune which will include the accessport for $850. It may be overkill to do a pro-tune at stage 1, but I'll be staying at S1 for at least a year while getting peace of mind. Plus, building a relationship with a quality garage is never a bad thing. A big thank you to everyone for your input! Peace.
Brianmc27
Folsom, CA
Man, that’s a whooole lot of dough for a protune. You could get a lifetime tune from Adam at Tune+ for a similar price and just follow your upgrade path with your tune
Ontario, CA, USA
I got the Cobb RMM and immediately I noticed more vibration especially when the AC is on, but after about 300-400 miles the vibration reduced dramatically, minimal vibration at idle and a bit but not as much before with the AC
