So I recently installed some shims to adjust my rear toe and camber, but now the sensors that plug into the back of the hub can't reach the correct spot so I have to drive with abs off. Has anybody had to deal with this or have any suggestions.
Yes. You can’t use those shims unfortunately. You can use the -2 degrees Whoosh plates but not the traditional adjustable shims. Like Typhoon mentioned above, be sure to remove the backing plates.
If you decide to machine sensor relocation brackets let us know please. The ones I made didn’t work 😂
