My 17 (has about 22k miles) seems to occasionally have a really rough idle and it will stall, and this seems to occur only after the initial start up. I can keep the engine running by revving in neutral, and it runs perfectly at engine speeds above idle. I have not noticed the issue when the engine is warm, but that may be just because I usually drive the car for fun and then put it away, so it seldom gets started when the engine is already warm.
I've run into similar issues with the idle air control valve on a couple of Ford trucks with manual transmissions that I have owned, so that's what I am thinking is going on here. Any other thoughts? BTW, the check engine light is not illuminated.
