- Member ID
- #864
- Messages
- 4,567
- Likes
- 862
Another thing I'd like to see brought from the srt4 world to the fist ( I'm sure the srt4 was not the only car that enjoys this upgrade ).
http://www.shoprealtuned.com/product_p/rt-lcab-neon.htm
Lower control arm bushings.
I spent a ton of time trying to fix the wheel hop my srt4 had. Motor mounts, shearing motor mount bolts ( in 4 different spots ), and installing stiff engine trans mounts to try and stop it from happening.
Finally, I made a big purchase ( for me at the time ), and bought a set of solid lower control arm bushings like the ones above ( I did not buy THOSE bushings, just a set basically identical to them ). After that, the car never wheel hopped on the street, never broke a driveline part or had another issue ( for some reason, the exception was at the drag strip on drag radials ). But they greatly improved my traction and reduced wheel hop as advertised.
The fist may or may not have lca bushings that are upto the task, but judging from the RMM, I'm sorta doubting it.
The only downside to the solid lca bushings I saw was noise. They did make a slight bit of noise.
Anyone know of a shop or place that maybe interested in building a set for the fist?
