Sprayed150's get beat up in Street Touring autox thread!!!! WOOOO!!!!!
alexrex20
#41
next episode, you're swapping the cossie 2.5 into your FiST?
#42
One of those 300 WHP GRC Lights spec, Mountune built/supplied NA 2.4 liter Duratecs would be a cool swap into one of our rides, but nowhere near even close to street legal, or able to pass most state inspections. [:(] (Besides costing as much as TWO used FiSTs!)
#45
Sprayed150
Thread Starter #46
Unfortunately due to hurricane damage, the Bay bottom crawl for this year has been cancelled
ordered some HPS 5.0 brake pads for the front of the car, and have some itv22 plugs to gap and toss in next time i work on it. got a spray bottle for the tires and radiator/ic
event coming up this weekend for my local club so we will see how i PAX this event, itll be my first with the club on good tires since early this year. then 2 events next month. hoping to order some shocks in the next 1-2 months
Sprayed150
Thread Starter #47
So, tossed it on the dyno today. 90 degrees ambient, Mountune intake, ramair drop in, mishimoto tube, Stratified tune
#49
Is that an air field??
Your courses are O-P-E-N!!
Sprayed150
Thread Starter #50
its a fairgrounds, and i wanted to build a big fast course, this is the same place i am building the course for the state championships event in nov
#51
My best run today, 2nd in class by .4sec
looks like a fun area! my main comment is the U turn. you left tons of time out there on that. you could easily have put a full car inside of you, hug those cones!
Sprayed150
Thread Starter #52
i tried, it was real slick over there i went tighter in a few times and lost too much speed, the tighter line didnt offset it enough
im going to tke a bit of camber out of the car before states, maybe back down to 2.8 or 2.7, and try to get the koni yellows in the rear at least
#53
you can take the corner the exact same way with the exact same exit speed and everything, just initiate it sooner so you are only inches away from those cones instead of car lengths!
Sprayed150
Thread Starter #54
ah, i see what you meant, yea i left a bit on the table there
Sprayed150
Thread Starter #55
considering i am a koni dealer, i finally got around to pricing out the yellows for my car, im just a hair away from just ordering them...
#57
I've been looking at Eibach Springs but heard some positive and some negative comments, there seems to be some feeling that at least in the rear with or without these springs the car is greatly improved with the Yellows.
Sprayed150
Thread Starter #58
they have been fine springs for the most part, i got the ones that drop less than an inch. id really like anotehr 20lbs or so rate to them, but it is what it is
#59
Probably my very next mod, even before the ST200 air box setup, or seats/steering wheel.
Will get the rears only at first, hoping that Ground Control FINALLY makes up their minds to develop a coil over conversion kit for the front Koni Yellows some time within the next year (but I am not holding my breath since this car is 'dead' as of next year in North America :( ).
IF they have no plans for the above, I will just get some Swift Spec R springs, throw them on the front Konis, and the back, and be DONE with the suspension, at least until someone possibly releases a REAL TRUE affordable individual 3 way adjustable coil over system for this car. ;)
Sprayed150
Thread Starter #60
lol i feel you, im a dealer for MCS and it makes me apprehensive looking at prices
