Sprayed150's get beat up in Street Touring autox thread!!!! WOOOO!!!!!
Sprayed150
Thread Starter #201
Track night in america tuesday night, hopefully ill have my new tires in 2 weeks, may grab the eibach bars to try for the pro
PhoenixM3
Nice! I noticed your G meter for accel/decal seems backwards.
Sprayed150
Thread Starter #203
did TNIA last night on the street tires, first session got 1 clean lap and was held up by a slow driver in a mustang that refused to point anyone by, he was running 14 sec slower laps than me in a 500hp car. the 1 clean lap i had was my 2nd one out and was about the same as i ran last time i was there on the good tires. 2nd session, got stuck behind him again and when he finally let me by, i blew the symposer delete out at 110mph and that ended my night. after the event i was able to go out and found it in the grass so it was just an annoyance.
upside, coolant never got above 210degrees and oil stayed under 235. pre radiator it did 245water and 260+ oil.
felopr
cool stuff on the radiator
Sucks about the symposer plug, time to invest on t-clamps lol
Sprayed150
Thread Starter #205
yep, on my list, just have to measure for size lol
One of the reasons I used the expander plug directly into the charge pipe symposer nipple method, and then put one of those Sure Motorsports silicone 'caps' over THAT with a strong clamp. ;)
felopr
i was running a expansion plug before but quickly bought a symposer plug, i was always thinking in the back of my mind that the expansion plug would fail under boost and the plug would just fly up making a hole in the bonnet lol
That's why I put some thread locker on the threads, and then put said cap over the whole assembly with a Turbosmart constant tension clamp. ;)
Sprayed150
Thread Starter #209
OK, so i am on the reg list for both the ft meyers prosolo and the dixie champ tour, mar 9-11 and 16th through 18th. going to order my tires tomorrow. trying to get any last minute parts for the car in and on in preperation
Sprayed150
Thread Starter #210
Tires are ordered, some 205/50/15 rival s 1.5's for my TD 15x8s and indy 500's for my street wheels
also, Ron has a catted DP on the way for me!
Sprayed150
Thread Starter #211
Got my downpipe from ron at whoosh today! Going to put it in early next week and hopefully sneak in some dyno time before I leave Thursday for the prosolo
Good luck. I hear it's... fun...
Sent from my SM-G950W using Tapatalk
Sprayed150
Thread Starter #213
Dp is in, it is pretty, thanks to ron@whoosh for getting it to me
tires mounted and balanced for the event on my 15x8s and new tires on my now street wheels, going to need a 5mm spacer to push them back out a bit
going to try and get on the dyno wed or thursday still, but the car feels pretty strong up top compared to before and def sounds better with more of a gurgle.
Ohhh those tires look meaty
Sprayed150
Thread Starter #216
225/45-15 Rival S 1.5s?
205 50, the TD's i got from a member on here, they are the flush fit ones, 225 would rub the wheel wells
working on picking up a miata end of the month to run in STS or SSM, that will have some meat on the tires
Plainrt
Those tires fit well on that rim. Could you let me know if get any rub on the swift setup and the 15x8s. And good luck at event ;)
I also have to admit that they do appear wider than most 205s in that pic (even if they are not in actuality).
The fact that they are on an 8" wide wheel DOES add to the tread width somewhat over lesser wheel widths. [:)] ;)
Sprayed150
Thread Starter #220
DP fitment is excellent, im going to make a thread once i hit the dyno and post events about it.
the BFG's are wide for a 205 from what ive been told
