- Member ID
- #38443
- Messages
- 1
- Likes
- 0
Good afternoon.
I drive a Ford Fiesta ST150 & my gears feel stiff, I am well aware that this issue is common, I've done as instructed for the common issue, I've used a 12mm drill bit & greased up the common sticking points (Issue is still there. The biggest change I've made to the gear shifting component so far is replacing the interior shifter bushing with the metal alternative, I've tightened it by hand via an 1/4 extension (Didn't use a ratchet)
I am a bit lost at the moment.
I am thinking of replacing the pivot arm with the mountune one (when they get back in stock) to see if that fixes my current fault
I hope this post was detailed enough.
