Symposer Failure?
Buffalo Grove, IL, USA
A few days ago, my FiST started sounding...odd. As if there's a leak in the exhaust system - or as if the Symposer hose is disconnected. Presuming it's the latter,
am I likely to lose some boost pressure? Or is the thing only transmitting sound?
Thanks
2019 Magnetic ST
Currently 15" black steelies w/Blizzak WS80s
Spork1569
Fillmore, CA
Thanks - but this doesn't actually answer my question about losing boost pressure...
If it's disconnected or leaking you can lose pressure. The sound symposer is connected off of the cold side charge pipe so if it's disconnected you'll basically have an open hole in that charge pipe where the pressurised air can escape.
