TB Bars & Depo Pipes
Hello all. I just installed a TB Performance traction bar and torsion bar and I can't recommend them enough. However, my Depo hot side IC pipe is rubbing on the bar at low rpm and making a loud noise. Has anyone experienced this or know what hot side pipe would work better with the TB bar? Maybe a silicone pipe instead of metal? Thank you.
I ran into the same problem with my pierce brace, my suggestion put a dent into the pipe. This will create enough clearance. As far as I know, pretty much all of the hot side pipes will have clearance issues.
