Timing Belt Water Pump Kit
Raymore
Just asking because I haven't found it anywhere online.
When folks are doing their timing belt and water pump are you getting a kit or buying the parts ad-hoc from Ford?
Searching around I found a Gates Kit for $190 but if I part it out straight from Ford it's $290. Obviously I'm leaning towards ford because I don't want shoddy parts doing this.
Curious what others have done/ran into.
CA
Just finished mine. I used the Gates kit from Rock Auto. Gates makes good stuff. I was a little concerned about the waterpump but when it came in I thoroughly examined it and it was quality.
jingo5
Raymore
Been looking at the different Tool kits on amazon. Curious what you used if you went authentic or "knock off"
CA
I actually bought two knock off sets. One had no brand the other was DPtools. The DP tools kit was much higher quality.
CA
Yep, I made a seperate post here.
It was not an easy job. Electric ratchet, extensions, swivels and a good breaker bar are a must.
CA
Any lessons learned, gotchas for the rest of us?
Also while it's apart I would walnut blast the intake valves. Mine were pretty crusty. I just used a shop vac and cheap blaster from Harbor freight. Didnt turn out perfect but a million times better.
