Tire Rack TPMS Help !!
I just got some new wheels/tires from tire rack with there TPMS sensors installed as a package. The problem is I can't get them to program. I've tried what the manual says in learning mode letting out pressure slowly and fast a dozen times and it fails every time. Then I tried the technique used on here pressing the start button etc using a universal tire programmer and no joy. Again I tried going fast and slow nothing so do I need the official ford programmer or what am I doing wrong. My car is a 2016. Any advise would be greatly appreciated
Turbo65
Cheers I will order one and hopefully that works
haste
it should, ive been using it for over a year now and have swapped wheels/tires many times. works like a charm.
Turbo65
Thanks, I just ordered one so I'll see on Tuesday when it gets here
That reset procedure you tried is just to learn starting pressures on existing TPMS. You'll be good to go when the triggering tool arrives.
Turbo65
Cool, thank you
Discount will do TPMS programming for free. Just stop by, it takes 5 minutes.
Turbo65
That's good to know, thanks
