traction control light, comes on after 10 minutes of driving loose rev counter and power,had it checked by my local mechanic, on his meter reading it,
Brighton
traction control light came on after around 5 minutes, took it to my local garage and had the plug in sensor reader, it said crank shaft sensor, so had it changed, but still did the same problem, the fiesta st is a 180, 2017 with upgrades, and a viper alarm, could it be the alarm?
Ireland
Check to see if any pipes relating to the turbo have blown off the larger the intake pipe, they relate to the turbo and affect all sorts of parameters including the rev counter dying, low power, etc.
Amycutts
High Wycombe
Did you manage to get this fixed? I have just had a new wet belt done on my fiesta and it was fine when it went in the garage and since getting it back it’s been doing this but the garage cant seem to understand what’s wrong
