Turbosmart Kompact Shortie Dual Port Blow-Off Valve for Fiesta ST
#41
Gents, what do you have your BOV set at?!?
all the way soft? 50/50? Results?
#42
This! I just installed this BOV and am getting a fluttering sound upon throttle release. Does this mean I need to go softer?
#43
Searched but didn't find what I'm looking for.
I tossed in my used Turbosmart Dual Port Shortie etc etc BOV on my FiST last night. Because it was used and I took it apart to clean and replace the o-rings, I'm not 100% sure it's adjusted correctly. Below is how my car acted before and after the BOV swap. Any feedback is appreciated.
Small throttle closure:
Stock recirc valve - small hiss from the recirc valve
Dual Port - nothing, no releases of pressure
Medium throttle closure:
Stock recirc vavle - hiss from the recirc valve
Dual Port - hiss from the BOV and turbo flutter thru the intake
Heavy throttle closure:
Stock recirc valve - hiss from the recirc valve
Dual Port - loud hiss from the BOV and not sure about flutter as the BOV is so loud
I'm also noticing it takes a little longer to build boost at medium throttle acceleration but it definitely builds and its strong. Peak boost is down maybe 1 psi.
Should I rotate the adjustment harder or softer?
Also, under light driving, inbetween shifts when the BOV does relieve pressure, it seems to stay open the entire time the clutch is depressed/between shifts...is it normal for it to be open that long?
#44
Just Ordered one of these through MODBargains.com great to work with!
