Very slight oil burning smell when coming to a stop. Is my list of stuff to check correct?
#41
Hey Clint, do you think the oily smell you got when you had the 2JR intake was precursor of the current problem you have or it's unrelated in your opinion?
Clint Beastwood
Clint Beastwood
Thread Starter #42
nah I think that is just the 2j/pcv farting oily air right next to the cabin vent inlet. It gets a lot better if you put some high temp foam between the 2j filter and the cabin air inlet
Clint Beastwood
Clint Beastwood
Thread Starter #43
So I’m getting a new Evap canister, part on order. Reset my mpg meter and drove oc to San Diego and back and got 18mpg on the freeway. Can evap affect fuel economy that dramatically?
#44
Has absolutely no impact on fuel economy....it just moves fuel vapors around in the evaporative emissions system.
Clint Beastwood
Clint Beastwood
Thread Starter #45
Well they replaced a "vapor management valve" and the associated hose. Before dropping it off I did a loop from Orange county to San diego and back and was getting ~19mpg at freeway speeds. Since I picked it up today, I put ~7 miles on it and the average is already up to 23mpg, and its popping a lot less when decelerating. Didnt' drive it enough to see if being in the care still causes a sore throat.
#47
I wanna say it's a purge valve as that also "manages" the fuel vapors...I think they are just getting fancy with their nomenclature.
Clint Beastwood
Clint Beastwood
Thread Starter #48
I did notice that driving the car back from the dealer, I didnt' get the scratchy feeling in my throat I'd been getting lately. It seriously felt like I was breathing uncatalyzed exhaust
PunkST
#49
^ thats been my driving experience lately. I replaced the purge valve and canister last year though.
Clint Beastwood
Clint Beastwood
Thread Starter #50
smell your oil and see if it smells like gas. I don’t think my issue was purge/evap alone, but the car already seems happier, mileage average is still creeping up (all stop and go miles, not freeway) and the frequent popping ( not good/cool popping!) has stopped so far.
Clint Beastwood
Clint Beastwood
Thread Starter #51
Was your fuel economy terrible before replacement?
PunkST
#52
Yes and its stayed the same for me. I went from cruising getting 37 no problem ( its all 55 mph back roads to and from work) to hovering at close to 32 😕.
Clint Beastwood
Clint Beastwood
Thread Starter #53
I'm cruising at 38-42 on the highway right now, but since only ~10% of my driving is highway my averages are bound to be low. Even so, with the same driving cycle, my average mpg is up to 22 which includes the previous average of 18.7mpg highway. It's creeping up more and more. I think I still smell some burning oil a little bit even after I steam cleaned it. I think I'm going to change the oil at ~800 miles, as the oil still smells a little gassy and last time I filled up I didn't use my usual oil, I used a synthetic blend (that still met the spec).
PunkST
#54
I'll check for a gassy smell here. My car love to be a mystery. It ckuld just be the symptoms of no catch can ever starting to show up.
#55
Is there oil inside the spark plug area in the head by the Coils? Could be a source of oil Burning smell...Food for thought.
Clint Beastwood
Clint Beastwood
Thread Starter #56
I'll take a look. Just swapped plugs a few thousand miles ago so perhaps. The weirdest thing was that it was just running *so well*!
PunkST
#59
Should just have to pop a coil off and shine a flashlight down there.
Clint Beastwood
Clint Beastwood
Thread Starter #60
With how the car was smelling I wanted to take a look anyways. Hands weren't working this weekend so it's still on the agenda to check 'em when they loosen back up.
