Wing plugs (for those that want the hole closed off when running wing risers)
CanadianGuy
Southern Ontario
For those that don't like the holes when using a wing riser kit a 2 1/4 npt plug is just about the right size. Soft enough to easily cut and drill a hole to pass the wire. Now if you have not cut your wire to install a 3rd light flasher you will need a bigger hole or cut a slot to push the wire in. Also put the hole to one side as the tube and wires are not dead center. To be honest this is not required as the holes are there before the riser anyway and I had plenty of dust in the wing. If you do this make sure to have long needle nose to drag (carefully) the wire and hose while you push.
jeff
Evans
McMaster Carr. Will try to post a part number later.
Good man, please do follow up on this, I scanned their website for several minutes and could not find the plug you bought.
Thanks!
CanadianGuy
CanadianGuy
Southern Ontario
Thanks!
Oh I forgot about posting that. Thanks for the reminder. I took 2 3/8 but 2 1/4 would have worked better (no cutting to fit).
DEO3
Sarasota
Hey man, thanks for this thread - I just installed my wing risers and the very first thing I thought was 'uhhhhh, what about these giant holes that are now exposed in the wing?' I just ordered the 2 1/4 plugs, hopefully they work well.
