Which Fiesta ST Intercooler did you choose?
  • Mountune
    Votes: 69 11.7%
  • PERON
    Votes: 7 1.2%
  • Airtec
    Votes: 19 3.2%
  • ATP
    Votes: 10 1.7%
  • Cobb Tuning
    Votes: 74 12.5%
  • Forge Motorsport
    Votes: 1 0.2%
  • Levels Performance
    Votes: 9 1.5%
  • Mishimoto J-Line
    Votes: 32 5.4%
  • R-Sport
    Votes: 5 0.8%
  • Deadhook Motorsports
    Votes: 47 8.0%
  • Depo Racing
    Votes: 102 17.3%
  • Mishimoto (Direct Fit)
    Votes: 21 3.6%
  • Modern Automotive Performance
    Votes: 27 4.6%
  • Custom Performance Engineering
    Votes: 40 6.8%
  • MTC
    Votes: 15 2.5%
  • Other
    Votes: 113 19.1%
  • Total voters
    591
I ended up buying a used Cobb intercooler on a deal I couldn't pass up. I don't have an Accessport yet, and probably won't get one till a couple of months, can I run the intercooler on the stock tune?
I know it won't make a power difference at all, just wondering if it the cooler air will mess with the tune.
Quisp
No you'll be fine.
I'm on a stock tune and my MAP intercooler raised my whp from 181 to 191 on the same dyno despite even hotter ambient temps than when I went the first time.
I chose the DHM race intercooler and crash bar. Well worth the wait!
Going onto a stock turbo setup, or an aftermarket upgrade??
I am using it on a stock turbo right now. I added that and a drop in filter and am running an off the shelf cobb stage 2 tune. Eventually going to a bigger turbo.
Does biggest size really translate to best performance?
No but size definitely helps the cooling efficiency. The best intercooler will be the one that balances max cooling efficiency with max mass flow rate. For our tiny turbos the flow rate is more important but the difference between the MAF of aftermarket intercoolers is pretty marginal (+/- 3 lb/min)
Okay that's what I was assuming just wanted to make sure.
This info was originaly posted by razorlabs I added a couple more ic's to the list, if its already been done apologies in advance,
btw thinking about going with deporacing if they get them back in stock any input welcome.
Stock FiST IC
Core Dimensions:
27.5" x 5.25" x 2"
Core Volume:
288.75 in
The list is in order of Core Volume.
DHM Race Intercooler kit with crash bar
Core Dimensions:
24" x 10.5" x 3.5"
Core Volume:
840 in
97.6744% difference over OEM FiST IC
34.3096% difference over Mishimoto J-Line IC
Wagner Competetion FMI
Core Dimensions:
26.37" x 10.62" x 2.75"
Core Volume:
772.74 in
91.1907% difference over OEM FiST IC
26.1557% difference over Mishimoto J-Line IC
Mishimoto J-Line IC
Core Dimensions:
22" x 7.2" x 3.75"
Core Volume:
594 in
69.1589% difference over OEM FiST IC
18.1818% difference over Cobb IC
c-pe core fmi
Core Dimensions:
29" x 6.25" x 3"
Core Volume:
543.75 in
61.2613% difference over OEM FiST IC
9.3863% difference over Cobb IC
Deporacing 3.0 FMI
Core Dimensions:
28" x 6" x 3"
504 in
54.3046% difference over OEM FiST IC
7.4074% difference over ATP IC
Cobb IC
Core Dimensions:
27.5" x 6" x 3"
Core Volume:
495 in
52.6316% difference over OEM FiST IC
5.6075% difference over ATP IC
MAP Maperformance Intercooler
Core Dimensions:
27" x 6" x 3"
Core Volume:
486 in
50.9197% difference over OEM FiST IC
3.7736% difference over ATP IC
ATP IC
Core Dimensions:
24" x 6.5" x 3"
Core Volume:
468 in
47.3736% difference over OEM FiST IC
1.2903% difference over AIRTEC IC
DHM Factory Fit
Core Dimensions:
22" x 6" x 3.5"
462 in
46.1538% difference over OEM FiST IC
9.4122% difference over Mountune IC
AIRTEC IC
Core Dimensions:
28" x 6" x 2.75"
Core Volume:
462 in
R-Sport Stage 3 Garrett Intercooler
Core Dimensions:
24" x 6" x 3"
Core Volume:
432 in
39.7503% difference over OEM FiST IC
10.219% difference over Levels IC
Mountune IC
Core Dimensions:
29.25" x 5.75" x 2.5"
Core Volume:
420.47 in
33.8129% difference over OEM FiST IC
4.0816% difference over Levels IC
Stock FoST IC
Core Dimensions:
26" x 6.25" x 2.5"
Core Volume:
406.25 in
Levels IC
Core Dimensions:
26" x 5" x 3"
Core Volume:
390 in
29.8343% difference over OEM FiST IC
19.6224% difference over Mishimoto Z-Line IC
Mishimoto Z-line IC
Core Dimensions:
26" x 5" x 3"
Core Volume:
320.31 in
10.3635% difference over OEM FiST IC
Which of these require cutting? cp-e? and mishimoto j-line?
Deporacing seems like quite a good choice but the website looks a little unprofessional which worries me.
TUX15ST
its crazy how long some people have been waiting for these consider you can get and MTC (essentially the same exact unit) for basically the same price delivered to the US in 2 days.
TUX15ST
Link?
here you go, its $320 shipped today (prices change slightly each day with exchange rates, I think I paid $340 a few months ago), I ordered mine on a thursday and it came the next monday so only 2 business days from the UK. Same core as the depo/cobb/airtec, a lot of peope running these without any issues. I had a Depo IC on my FoST and was planning on getting one for my FiST but no way I was waiting this long for the same thing.
http://www.ebay.com/itm/MTC-MOTORSP...493972?hash=item3cff6edf54:g:4A4AAOSwLVZVt1Fn
Everything I've read on the MTC was really good. Works just as well as all the other intercoolers listed above only thing I heard was the some of the welds weren't as pretty but they are just as strong
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I'll have to check out the MTC then. Wasn't aware either product was MIC but it explains a lot of the pricing.
Maybe I'll have to look at a similar size one that's made in America - I've looked at Cobb and I'm not sure that that's going to do it for me.
Sent from my SGH-M919 using Tapatalk
Broke down and ordered the MTC Sunday night. It arrived today so I missed out on this, but the MTC and Depo are pretty similar.
Kudos to those who waited. I'll be ordering a DP from Depo someday!!
