Rally Innovations Splitter
caliboy15
seen it, it's ok. it's thinner than my Bojix
BoostBumps
Interesting....
Aluminum Plate / Powder Coat - Satin Black / $249
rooSTer
Saw it before...not sure if I like the look. But if its functional it might be good from some people.
meFiSTo
Would be interesting to see how far back that goes and if it is attached to some structure under there (radiator support?) with some brackets.
FistSt215
Why do lips cost so much for fist . When I had my speed 3 there's lips for under 100 bucks shipped !! Sorry end rant lol
x2 would like to know how it attaches.
It says 3 pieces on their site.
Looks like it does not really fit well as just flat metal against the shape of the area past the middle of it, not sure how it will function that way. Someone could make there own pretty easily with a sheet metal brake for a low cost DIY project.
The way the ends turn up is interesting, I gives me ideas for the track version of the undertray I am using:)
the duke
You're better off building dive planes, that vertical piece will do zero on this application as it stands. There was an old issue of RCE where they did a wind tunnel test of a Noble and performed a series of tests with a stock splitter, a stock splitter+dive planes, and a stock splitter+dive planes+side plates. The dive planes had the greatest affect (providing a nice scoop to trap air pressure).
Here
http://www.nobleforums.com/showthread.php?3988-New-Noble-aero-article-in-Racecar-Engineering
I've seen people take C6 Z06 plastic pieces that attach around the front wheel well and use them on other cars.
The black plastic piece, keeps air off the wheels (and it's subsequent vortex) as well as providing a ncie frontal area to push air around the car.
BlueBomber
not like you can buy one yet anyway
im getting their splitter, side skirt diffusers, light bar and wing fitted to the car for fab fords
ill see you there and you can check it out there
I agree on covering the air that hits the tires as I have built a C5 Z)6 with Cr World Challenge body and a widebody C6:)
As well as used dive planes.
My thoughts on this would be to add to the TR splitter and DIY under tray, add and aluminum extension to the splitter sticking much further out and wider then maybe bend the ends up to meet with sections to block the air from the tires.
I am running 15x9 wheels with 225 race tires all around and can go up to at least 245 on the front but already out in the airflow so this would be pretty important for my setup.
I did not think about the Z06 parts, they are cheap, I guess I better order some if wide enough, thanks:):)
Rick
Perfblue15
Any more pics of the splitter? I can't decide between this one and the triple r for my car
