Dr.Prutteklutt's Clubsport FiST
Dr.Prutteklutt
Thread Starter #81
I have a few Friends that are driving this Tire on Tracks, on a Golf 7R as a exampel, and they are satisfied with it, so i ordered a Set.
For that little amount of Money its worth a try :)
Izzy
#82
Definitely interested in how they perform in the wet especially knowing if they have the tendency to hydroplane.
Dr.Prutteklutt
Thread Starter #83
I bulid myself a new Shifter [wrenchin]
Works well.
I wanted to get the Shft Knob near the Steering Wheel because its more useful on the Track.
#84
That tablet(?) looks great over there! Is your reverse shift still at the bottom?
shouldbeasy
#86
Your interior is way different than the CAD spec!
Dr.Prutteklutt
Thread Starter #87
I did some Rounds today to test the new Tires.
It was 86F outside and i lowered the Tire Pressure to 29psi Front and 26 on the Rear.
After the Tires gets warm they created a very good Grip [pray]
I already dont know how they are in the Wet...
I am very satisfied how they perform and would highly recommend them for Track use [like]
On daily use they perform like normal Street Tires, they must be warmed up to get the Grip wich is almost impossible on the Streets.
#88
Are you getting an oil temp reading with torque? Mine is not getting data for that. I'm guessing it could be my obd adapter.
Sent from my SAMSUNG-SM-G870A using Tapatalk
KKaWing
#89
Post #62, he has a sandwich plate.
Dr.Prutteklutt
Thread Starter #90
Thats normal, you can not get the Oiltemp from the OBD.
I use a seperate Sensor in the Sandwich plate and Gauge in the Vent Pod :)
#91
I can see the oil temp using the access port, but not through torque.
Dr.Prutteklutt
Thread Starter #92
ah okay, for the Europe FiST there is no sollution to see Oiltemps, there is not even a Sensor for it, so i build something [wrenchin]
#93
Ah well that's no Bueno and strange that there is that difference in the cars system.
#94
Looks great Marcel!...wish we had the 2 door version in the US! So green with envy!...[vommit]
x 1000!
That car in white, with those wheels, in 2 door, just looks like HEAVEN!! [twothumb] [driving]
#96
So, the oil temp is absolutely a reported OBD2 CAN BUS reported PID on the USDM cars??
#97
Works well.
N-I-C-E job on that shifter extension (as well as ALL of the other meticulously engineered/executed mods on your little touring car!). [twothumb]
#99
When I'm using my access port I monitor it, so yes.
THANKS, GREAT to know, as that's one less gauge I have to install since I can use my Kiwi Wi-Fi OBD2 scan transmitter, and the Dash Command app on the iPod, OR the AP once I get that. [thumb]
For some reason though I cannot get the torque app on my phone to see that data through my bt obd adapter. I am using a very cheap adapter though so that is probably the problem.
I would love to have a 2 door also, but I have enjoyed the ease of loading and unloading things with the rear doors.
