Dr.Prutteklutt's Clubsport FiST
Dr.Prutteklutt
Siebengebirge
Thread Starter #81
I have a few Friends that are driving this Tire on Tracks, on a Golf 7R as a exampel, and they are satisfied with it, so i ordered a Set.
For that little amount of Money its worth a try :)
Izzy
Houston
#82
Definitely interested in how they perform in the wet especially knowing if they have the tendency to hydroplane.
Dr.Prutteklutt
Siebengebirge
Thread Starter #83
I bulid myself a new Shifter [wrenchin]
Works well.
I wanted to get the Shft Knob near the Steering Wheel because its more useful on the Track.
Dr.Prutteklutt
Siebengebirge
Thread Starter #87
I did some Rounds today to test the new Tires.
It was 86F outside and i lowered the Tire Pressure to 29psi Front and 26 on the Rear.
After the Tires gets warm they created a very good Grip [pray]
I already dont know how they are in the Wet...
I am very satisfied how they perform and would highly recommend them for Track use [like]
On daily use they perform like normal Street Tires, they must be warmed up to get the Grip wich is almost impossible on the Streets.
#88
Are you getting an oil temp reading with torque? Mine is not getting data for that. I'm guessing it could be my obd adapter.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Dr.Prutteklutt
Siebengebirge
Thread Starter #90
Thats normal, you can not get the Oiltemp from the OBD.
I use a seperate Sensor in the Sandwich plate and Gauge in the Vent Pod :)
#91
I can see the oil temp using the access port, but not through torque.
#93
Ah well that's no Bueno and strange that there is that difference in the cars system.
Works well.
N-I-C-E job on that shifter extension (as well as ALL of the other meticulously engineered/executed mods on your little touring car!). [twothumb]
For some reason though I cannot get the torque app on my phone to see that data through my bt obd adapter. I am using a very cheap adapter though so that is probably the problem.
I would love to have a 2 door also, but I have enjoyed the ease of loading and unloading things with the rear doors.
