Thread Starter
#41
Thread Starter
#41
Update 8/20/15: Exhaust Testing
As promised I did some dyno testing with our catback. I was floored when I saw the results, they were pretty stout! All testing moving forward will be done on a Cobb Stage 1 tune to keep consistent results, once the preliminary testing is done I will do a custom tune for everything installed and compare against Cobb's OTS maps for the corresponding modifications.
Cobb Stage 1 results on a completely stock Fiesta:
Cobb Stage 1 results with MAPerformance 2.5" Stainless Steel Catback:
As you can see there was a SUBSTANTIAL gain in power with our catback installed. I do realize there is a 300rpm difference in the run start time but that doesn't make any difference after years of testing peak power and torque still hits at the same RPM regardless. Not only is there is a HUGE peak increase in both HP and TQ, but it is across the entire powerband, absolutely insane!
Below is the boost vs rpm log from each run. You can see that peak boost was exactly the same for both runs, as the tune was not altered in anyway.
Just in case you missed it, here is the video!
[video=youtube;Tfqx4P2pJ_Y]https://www.youtube.com/watch?v=Tfqx4P2pJ_Y[/video]
If you have any questions please feel free to post up, I'm here to supply any info I can!
Thank you,
Adam Brunson
Thank you,
Adam Brunson
