- Member ID
- #7653
- Messages
- 222
- Likes
- 94
Yeah, I don't even have the ~$2500.00 right now for even the R1 Bilstein motorsport strength gravel setup, let alone the $8500.00 to $12,000.00+ for the R2/R5/etc. Rieger gravel or tarmac setups. ![Frown [:(] [:(]](/images/smilies/frown.png)
Maybe the Ground Control conversion deal when it finally is released will allow a little bit higher than factory ride height, even if it means using a different/taller spring height than what they supply with the 'kit'.
I did some gravel rips on the SES with standard set up, and it was fine. MUCH better with the KW V1s due to the much improved suspension specs, just much less clearance... not sure what height... I set the height on those by finger width[emoji849]. Maybe two inches lower than normal ride height.
Unless you are doing fire roads or rutted single track, ALL the options out there for the FiST are just fine. I did finally get my Bilstein B8s and Swift springs installed on the FiST, and leaving for a trip to NE British Columbia shortly... lots of good gravel up there... [emoji848]
Sent from my iPhone using Glue and macaroni
