225/45 r17
Healdsburg
Since I haven't been able to find a 225/40 r17 that isn't a track or autocross tire I was wondering if a 225/45 r17 would work with a 17x8 wheel. If anyone is running this or have heard anything about it please let me know, I dont want to order everything and have it not fit or rub too much. I have stock suspension and my fenders are not rolled.
Clyde
I'm running 215/45's on the stock rims and stock suspension, I get a little rub on the fender well on really big bumps and some medium bumps if i'm at full lock. I think 225/45's will be pushing it.
Tanner77
Healdsburg
So then I guess my next question is that what tire should I use with a 17x8 set up?
Tanner77
Healdsburg
I'm scared to go 225/35 because I don't want to damage the wheels. Unless someone is doing this and hasn't had any issues
Gilbert
^^^Yeah but it is an aspect ratio. The sidewalls will be pretty similar between a 225/35 and a 205/40.
Carson City
It is an aspect ratio and arbitrarily used my manfs as well, look at the real specs, diameter, section and tread width. While your at it look at weight, heavy tires will hurt performance in all ways so you want to go as light as you can find the tires that will fit your needs.
