RMM Torque Numbers
Huntington Beach
So I'm going to install my new RMM today or tomorrow, and I don't know torque specs... I've seen mountune say 24Nm which seems super low, and people say 50 ft-lb (~70Nm) and I'm just wondering which is right, I don't want to fuck this up so anyone know what its supposed to be?
CanadianGuy
Southern Ontario
Mountune is correct. If you are concerned add for medium strength (removal) thread lock. Remember the block is aluminium and over torquing will mess up the threads. You will also see when removing them they are low torque.
BiigMe
Huntington Beach
Well in this thread:
http://www.fiestastforum.com/forum/threads/1389-Cobb-Rear-Motor-Mount-for-Fiesta-ST-Installed-Review/page8
They say that Ford recommends 50 lb-ft for the bolts, which sounds a bit better than what Mountune says. I mean Mtune doesn't even have you torque it down to 18 lb-ft, which is less than the Oil drain Plug torque specs... Either way what do you recomend for thread lock? Blue Locktite OK? I also saw someone say something about copper grease is that necessary?
CanadianGuy
Southern Ontario
Grease it if you want (I did). And thread lock blue is always a good idea as it will actually prevent the bolt from seizing.
