Installed the GFB DV+ that I got from  [MENTION=3660]RaptorRacing[/MENTION]. Very sturdy and precises piece. Just the gauge of the spring compared to stock is an indication that this part will outlast the stock part. There is no need to break the stock part with pliers. Just push with your thumbs one side then 90 degrees from that spot and keep going around it will pop tight out. I really like it. I torqued the bolts to 3 rapped knuckles. What I tight place to work on. I only had the car jacked up enough to get the wheel off as I did not want to take the skid plate off I was working from the wheel well. I ended up using a flex extension and a bunch of wobbly extensions to get the wrench out from the engine bay to do more than 2 click on the ratchet.  Worked great.
Quick drive and I do notice smoother shifting. The drop from boost to vacuum is not like the stock part takes about 1-2 seconds (need to log to be sure). The 1 to 2 shift is no longer as jerky. Upper end shifting (3-4-
speeding ticket-
jail) is almost like flat foot shifting.  Just with 20 minute of driving I recommend the part, especially if you do not want to cut a vacuum line for other kits.
