Mountune Fiesta MRX Turbo
antarctica24
The MRX Turbo will need an aftermarket BOV. Mountune sells one that connects where your sound symposer goes. You can also get the cp-e charge pipe with the BOV option.
I'm using the BOV that came with my MAP cold side pipe. It has a flange welded on the pipe to mount the BOV. Its a turbosmart, that has a external port, I connected a 6" piece of rubber hose to quiet it down a little bit.
Yea I would have to agree with you on that. Trying to muscle the turbo in position with one hand and tighten the clamp with the other was not fun. Thankfully I've got arms like Mr. Fantastic so I was able to maneuver around to make it work lol.
I used a ratchet strap to hold the turbo in place while I tightened the V-band. What a pain...
Brura22
Brura22
Thread Starter #1,243
Bout to do a full boost pull, woop!
I think my tick is fuel injectors...excited to get permission from Randy to go to slot 2 and see what this turbo kit is made of...
I took manifold off and assembled everything outside the car and dropped it back in. I felt that was easier than trying to do everything from underneath...
These DI motors are little tickers, could just be the injectors. You're gonna love it, I'm only on the 1st revision and it rips!
Nice! Yea I forgot about the MAP pipe, that's a good option too!
Brura22
Brura22
Thread Starter #1,248
Holy balls..
Brura22
Brura22
Thread Starter #1,250
It's good, huh? I'm considering this kit. How many miles are on your car?
18k, the new WG is awesome. I can 100% attest that there are gains with the new WG.
Super, glad you like it! I just hit 15k on my car and I'm still a bit reserved about adding a turbo due to the warranty but I'll probably give in sooner or later.
Brura22
Brura22
Thread Starter #1,252
If I blow this motor, it’s cause I did it. I’m pretty confident the motor in this thing won’t go bad from factory shit during the warranty.
antarctica24
Sent from my iPhone
Do me a favor what boost numbers are you seeing on slot 1 tune with the new wastegate. If randy doesn’t want you to post pm me. I want to make sure I got the preload correct before I try slot 2.
I thought install was pretty straightforward. I took the manifold off and assembled the turbo, vband adapter, and manifold all together outside of the car and dropped it in from the top. Used new gasket and manifold bolts for the reassembly. The coolant lines were the biggest pain in the ass, along with the bolts provided in the kit for the vband adapter that wouldn’t thread in.
Based
So is the new wastegate worth it? I still haven't installed my turbo lol
For the price, just do it. You won't wanna take that turbo off again unless you have to. Also you'll need a re-tune if you do it later like me which will cost you more.
Brura22
Brura22
Thread Starter #1,258
16 psi +/- 1psi
antarctica24
Ok, then appears yours is off as well. A 17 lbs spring should yield 17 psi with a maximum of 34psi with a boost controller. If your running on slot 1 spring only tune, you should max out at 17. I guess I am taking mine off again to re-adjust.
Brura22
Brura22
Thread Starter #1,260
I do max out at 17, just not every pull. Sometimes it’s 16.8, sometimes it’s 17.1, sometimes it’s 16.7
