Rota Grid Classics Hyper Black 16x8 +20 offset (4 sets ONLY)
Ish
Whats up guys, So i was looking for a 16x8 wheel for a while to fit a meatier tire but with not going to a 15in wheel. I ended up doing a custom order of these rota grid classics in our lug pattern. ETA is about 2-3 months and will need a deposit to confirm your order. I already paid for my set but i was asked if i could help selling the rest of em so i figured a few guys here might be interested in a set as well.
Tell them I sent you [thumb]
Price: $750+tax (needs 1/2 deposit and other half when orders complete)
Size: 16x8 +20 offset
Hub: 73mm
Color: Hyper Black
Contact info to order: 1-925-339-3828 call or text
www.18racing.com
or wheelbay on Ebay
These will look great on your car. Any idea of the weight? Will these fit with the 20 offset?...
Sent from my SM-N920V using Tapatalk
Ish
Ish
Thanks man, Yea I want more of an aggressive wheel setup. They weight 17lbs and they should fit, if not ill make it fit lol. It's going to depend on what tire I go with
i've been looking for these in 16x8 i even made a thread about it.. sign me up dude. damn you just made my day. isn't our hub bore like 63.4 or something though?
EDIT: Just called Jenny, putting in my deposit! If anyone wants these, the more people the better prices.
Ish
Ish
Sick man! Yea will need a spacer on the hub but that's about it. The offset is aggressive but that's the best they can do, just roll your fenders or fit a smaller tire and your good
yeah dude, the offsets fine, but where are you getting the spacer from? or if you allready have one, where? You think 215 tires will fit on it with stock fenders?' might be forcing me to go wide body.
Ish
Ish
That's what I'm going to try to fit. I'm looking at a 215/40 or 225/40. If you roll your fenders you should be fine. There was some guy on here that had some AGs 17x8.5 +30. So 16x8 +20 is definitely doable with a good fender roll/pull. I'm going to order the spacer online, I'll add a link to it later.
Ish
Ish
Update: hub will be in our size. 63.35mm
oh thank god, i didn't wanna have to buy spacers for it.
Technically, they are not "spacers", but hubcentric rings, but YES, it is a much more solid setup to have the wheel's bore diameter the same exact size as the hub flange. [thumb]
Damn +20?! I'm on 15x8 +30 and they stick out pretty far, you might need something a little more drastic than a roll, well depending on how low you go.
Ish
Ish
I'll make it work lol. It's also going to depend on what tire I'll be running but we'll see
If you were running stock height, you would be good wouldnt you?
Ish
Ish
Yea it should, as long as your tire size is not too tall/wide.
they should look pretty sweet. Though theres not a lot of options of terms of the tire. Probably a 215/40 to be safe
GAbOS
+20 and 16" on OE suspension. Update this thread when you hit a bump a certain way or take work friends to lunch. :D
Ish
Ish
Thread Starter #18
Looks like they'll be arriving this Monday. She still has a few sets left if anyone is interested.
