Clutch and/or Transmission Squeal
Langley
Hi Everyone,
I have a squeal or squeak that emanates from my Fiesta when cold. It lasts about 10 minutes and then stops. Only when engaging first gear from a dead stop.
I took a video of it, it does capture the sound from inside the cabin, but is fairly hard to hear. If people took a look and had any ideas or have the same issue, that'd be good info to hear!
https://www.youtube.com/watch?v=nw8GeAPkQag
thanks,
Eastern Florida
My clutch pedal is sometimes squeaky when I engage/disengage it. I think it's heat/humidity related and being in Florida there's plenty of both.
KentRatke
Langley
I appreciate the responses, I know the video sound is bad and the sound is faint to begin with.
Cheers everyone!
I believe that Kent is referring to an actual clutch disc contacting the flywheel engagement type of sound, and NOT the hot weather, clutch arm pivot point/return spring, or master cylinder creak/squeak so many of us are cursed with (myself included).
KentRatke
Langley
Yes, it is 100% emanating from outside/under the car
