I'll try to update you guys as best I can, as well as a rundown on the basics of the pod, if some of you are curious.
The pc board enclosure that I posted previously will be enclosed in a 3D printed "pod". The OLED display will secure to the front face of the pod. A lexan (or similar) faceplate will then adhere over the front face, with the display showing through a clear window. This assembly will then slide into the cubby in front of the shifter, and be held in with a screw in the back. The harness will also exit a hole in the rear of the cubby.
Other updates:
Fuel line and ethanol sensor kits have gone out to some testers, and they have been working great over the last few weeks/months.
Harnesses and displays will go in the test vehicles as soon as the final boards arrive and are assembled.
The pc board will be getting ordered this week with any design changes added, and this will be the final production board.
The graphics for the faceplate is in work, and that should be getting ordered shortly.
For now, I'll leave you all with a photo, showing the attention to detail I am putting into this gauge for you guys!
Other updates:
