D
Hi guys!
recently I bought mi Fiesta and it came with SYNC 3 v1.0, No Nav. Everything worked fine with it, media player, bluetooth, usb, etc. So one day I decided to register into the Ford website and on the SYNC section it said that there was an update available for my car. I thougt "cool, let's install it!!", so I downloaded the firmware, put it into a 32GB Sandisk thumbdrive (empty, FAT32 formatted), put it in the USB port of the car and the installation went well... or so it said on the screen (rebooted by itself in the middle of the process, just as the Ford website said it would). "Awesome, let's try it!", I said, the first thig I tried was the voice commands, and no luck. When I press the button on the steering wheel, it shows "Voice recognition not ready" and nothing happens. I tried all of the other functions (usb, bluetooth, phone, CD, radio, etc) and everything works just fine.
So I went ahead and went into the hidden menu (like THIS) to check the SW version and I found this:
As you can see, there's no Voice Control Application Version...
And here's the current version:
Needless to say that I already removed the fuse and put it back on after 15 min, same with the negative terminal of the battery, Master resetted it countless times and re-installed the update at least 5 times. Also tried to split the installation in half like stated here: SPLIT
Any ideas?
Anyone that can share the 2.3 version of SYNC 3 that actually works? that would be great...
Thanks!!
Any ideas?
Thanks!!
