Fiesta ST Spark plug tech
Sourskittle
Charge pipe fix
$10 for 2 of them. Lets see this MF-er pull off now !!!
Sourskittle
And yes Boostbumps, that's the area I'm talking about :) its a small area, but it does
Need filled.
I think NGK LTR7IX is the wrong plug for own Ecoboost engine fellas. I brought a set and noticed a difference in the centre electrode design.
I ran the plugs anyway but I notice it was a little harder to start from cold and run on 3 cylinders sometimes for a few seconds.
The OEM plug have a projected centre electrode, these do not. Link to NGK, http://www.ngk.com.au/spark-plugs/technical-information/projection
Image I took so you can see what I mean. OEM plug on the left.
My OEM plugs vs new ITV22
Been using ITV20(stock heat range) with stage2, but now at stage4 260whp i should probably put in the itv22.
I was told the itvXX is not the best possible plugs for this car, but the best option at the moment.
westcoaST
What is the socket size of the OEM plugs? 5/8"? Found it 5/8 thin wall spark plug socket.
We found the OEM specification for the spark plug GAP
what is the best gap plug to set? is it the factory recommandation? 0.031?
westcoaST
I'm basically at the point in my 91 octane tune with MAP where a colder plug is needed to prevent negative corrections during my logs. I'm going with NGK 6510 plugs with .028 gap. There are lots of reasons to change to colder plugs and gaps
westcoaST
According to Adam, he has been running them for some time without problem. I know the reach is shorter than OEM, but Adam at MAPerformance.com has has good luck with them. I hope to install mine either tonight or Friday so we can move on with my 91 octane etune. Then we do a corn tune.
pelotonracer2
pelotonracer2
Thread Starter #212
I'm running Brisks (one step colder) but the gap was set at .030
I think I will try regapping them to .028
BoostBumps
Curious as to what's the "reach" on these silver tipped plugs? i.e... how do they compare to OE plug reach?
http://www.fswerks.com/collections/...us-st-2013-on-1-step-colder?variant=457131141
The Brisk RR14YS spark plugs have a colder heat range compared to the stock spark plugs. For light modified 1.6L/2.0L, 2.3L & 3.5L EcoBoost. With projected tip
Spark Plug Heat Range
Heat range is the measure of how fast the spark plug tip dissipates combustion heat. It must do this in a precise and controlled manner so the spark plug will:
?Stay cool enough to avoid pre-ingniton and/or electrode destruction due to detonation.
?Run hot enough to burn off combustion deposits that would otherwise collect on the insulator tip and cause fouling that results in misfire.
?Adapt to specific engine characteristics and widely varying driving/load conditions.
Key Benefits and Applications of Brisk Silver Racing Spark Plugs
? Silver is the best Electric and Heat Conductor - the best material for performance and racing spark plugs
? Superior Ignition Ability Increases Engine Power
? Lower Required Supplied Ignition Voltage
? Good Resistance to Fouling and Easier Starts
? Race Engines and Engines with Hard to Ignite Fuels
? Supercharged / Turbocharged / Nitrous engines
? Excellent for Total Loss Ignition Systems
? Excellent Spark Plug Choice for any Vehicle, Stock or Modified, even for High Mileage Vehicles and Vehicles With Oil Consumption Problems
pelotonracer2
pelotonracer2
Thread Starter #214
Curious as to what's the "reach" on these silver tipped plugs? i.e... how do they compare to OE plug reach?[/I]
I don't really remember. heh. I think they looked like stock reach. I'll take a pic of the two together for comparison sake when I regap the Brisks. With that said, Adam says the Brisks suck, so I may change them out at some point for the NGKs. My ignition advance seems to be a bit inconsistant with the Brisks which he says has been his experience with them as well.
BoostBumps
thanks! that's very good feedback!
pelotonracer2
pelotonracer2
Thread Starter #216
The Brisks are shorter than stock. I took them out and regapped them to .028", subsequently cylinder #1 plug was so loose I could turn it by hand. I know I snugged them all tight when I put them in two weeks ago.
westcoaST
The NGK 6510 plugs are shorter than the OEM plugs. The gap on the OEM plugs was .031. I gapped the NGK plugs to .028. No difference in starting or running that I can tell.
BoostBumps
hey thanks for the update...I recall you mentioning having some issues in the past with timing corrections and wondering if you noticed any change in cylinder 1-4 timing corrections (pos or neg) observed moving to a cooler plug?
westcoaST
I ran two logs on Friday. No negative corrections. This was with a new tune.
BoostBumps
that good to hear, bet your relieved to see that! Are the positive corrections your seeing more consistent now across all 4 cylinders with these cooler plugs and narrower gap?
