What's up people.
Recently I installed a RamAir intake setup on my car, and this morning I added the final piece which was the crossover pipe. I thought I'd post a few pics and thoughts. There are a few other threads on this but I like making an independent review.
Previously installed were the RamAir panel filter and induction hose. So this review reflects only the crossover pipe.
PRICE - ****
$132 shipped, and total of $224 for all 3 pieces (crossover, induction, panel filter). That's pretty good I think compared to other stuff out there. Ron at Whoosh has these for sale, he's a great fellow to buy your stuff from.
QUALITY - ***
These guys are making a killing...yes these fit 99% perfectly but the crossover pipe is thinner metal that I expected. Weight savings, right? The quality is significantly less than a CP-E or Cobb intake, both of which I've handled. It's not gonna break or anything, but it wouldn't take much to dent it if it were dropped or used as an anti-zombie weapon or something of that nature.
FITMENT - ****
Pretty much perfect....there's plenty of room, everything goes on super easily. The pipe is touching the engine where the rubberized cover is (see pic), I think the stocker did that as well so it's no big deal, though it would be nice if they weren't touching and rubbing and all.
INSTALL - *****
From the time I opened my hood to the time I closed it was 55 minutes. Great fitment made install super easy. Of course I've removed the cowl/headlights many times so that cut my time down. But it is pretty simple. Make sure you know what size socket you're using before putting the pipe on, that will save you time. I chose to attach the turbo inlet coupler to the crossover first and then put it onto the inlet and tighten. There isn't much room to work but it's not that bad. Knowing your socket size before reaching down there makes it easier. Other than that, it's all super easy, no issues at all.
RESULTS - ???
As you can see from the pics below, where I compare the stocker vs. Ramair, the pipe is wider and has better flow undoubtedly. So in theory more cooling ability and power. Intake air temps did drop about 1-2 degrees compared to before install. I did a datalog before install, in a few days I'll do an "after" log and compare the two and report. According to Jason's intake comparison, the crossover gave the greatest gains of any intake mods, 20tq and 4hp. I'll see how the Vdyno compares to this on my car. Of course we have different setups but still it will be nice to see the results. I will say that the butt dyno felt a bit more torque, but this might be placebo and/or happiness over my newly installed part, you know how that is. Heck though, if it really does add 4hp and 20tq it's totally worth the money. I'll post the results when I get logs after a few days. I take temps and weight and barometric pressure seriously when I V-dyno. But it's still only V-dyno...so there's really no way to prove anything here. But it helps and it's fun.
SOUND - ****
Installing the crossover made a minor but nice sound change. There is more intake noise, but it's not the whooshy whishy type - instead it's the lower end bassy side of the intake noise, the rumble. Sort of like you can hear the engine just a bit more, but the growly part of the engine, not the breathing part. If that makes sense.
OK more datalog results/thoughts to come later, for now here are some pics:
PRICE - ****
QUALITY - ***
FITMENT - ****
INSTALL - *****
RESULTS - ???
SOUND - ****
