Ford Fiesta ST 2012-2017
EBC’S NEW BBK (BALANCED BRAKE KITS™) REPRESENT THE ULTIMATE UPGRADE IN BRAKING PERFORMANCE, OFFERING SIGNIFICANT REDUCTIONS IN STOPPING DISTANCES WHETHER USED ON ROAD OR ON TRACK.
Every kit is supplied with all the hardware you need to completely replace all equivalent components of your vehicles stock braking system, giving a firmer and more responsive brake pedal and allowing you to drive harder for longer without the onset of brake fade.
Yet unlike all other front ‘big brake kits’ on the market which solely supply the parts for one axle. Every EBC Balanced Brake Kit™ is a full vehicle upgrade and is supplied complete with matching friction rear pads to fit the original caliper and braided brake lines for the front + rear, ensuring a totally balanced brake upgrade that delivers maximum braking performance
Discs:
• Multiple disc sizes available – 300x28mm, 330x28mm, 355x32mm, 380x32mm
• Fully-floating patented EBC
Square Drive™ bobbin system
• 48 curved vanes for effective heat dissipation
• High strength aerospace grade aluminium hub, anodised black for increased heat radiation
Caliper:
• FEA optimised lightweight aluminium caliper, reinforced with high-tensile steel bolts for maximum stiffness
• Choice between full dust boot type seals for road use, or inner piston dust seals for track use
Pads:
• Supplied with EBC Brakes
Yellowstuff™ pads front &
rear, our flagship ultra-street
and track material
Brake lines:
• Front & rear stainless steel
braided brake lines included
Brake fluid:
• Supplied with EBC BF307+
racing spec DOT 4 brake fluid
Balanced is Better™
When it comes to performance braking, bigger is not better. Balanced is Better™
You would never fit upgraded pads in the front without also upgrading the rears. You would never fit braided brake lines on the front without also fitting them to the rear. So why have ‘big brake kits’ been sold as front or rear only kits for years? The EBC approach is simple, whenever upgrading the front, you must also upgrade the rear. That’s why every EBC front kit is additionally supplied with matching friction rear pads and braided stainless rear brake lines, at no extra cost to you.
Quality in every component
Every individual component found in a Balanced Brake Kit™ has been designed from the ground up to perform, right down to the very last bleed nipple.
Every single brake caliper metal fitting and brake disc drive bobbin is manufactured from stainless steel to ensure parts are long lasting and do not corrode. The brake disc bell and caliper brackets are machined from aerospace grade billet aluminium for high strength and durability. To finish off, every kit is supplied with EBC’s flagship fast street and track Yellowstuff™ brake pads.
100% Engineered, manufactured & assembled in the UK
Apollo Series brake calipers are cast in UK, machined in the UK, painted in the UK and then assembled in the UK. Reinforcing the EBC philosophy of providing quality British madebraking products yet at affordable prices.
With so many calipers in this segment of the market being bought in from far East, surely this is the ultimate testament to EBC’s devotion to quality. EBC are, and will always be a true champion of great British engineering.
Discs:
Caliper:
Pads:
and track material
Brake lines:
Brake fluid:
Balanced is Better™
