Replaced evap lines under hood no change
PunkST
Menasha
Well i finally got around to replacing the evap lines under the hood. Even wrapped them in heat reflecrive tape to hopefully make them last longer, didnt do it super tight so i wouldnt crack the new lines. I was hopeful that it was the solution to my multiple codes
P0442
P0456
P219A
It has not fixed the issue at all. Car still runs and drives the same, still the same mods.
So i need to know where the actual purge valve is. What other parts i need to order, and what other things to inspect. Cleaning the fuel neck and such hasnt changed it either.
PunkST
PunkST
Menasha
Thread Starter #2
Bump because im still searching for an answer.
MagnetiseST
Dania Beach
Whats the issue? What intake do you have installed? What lines did you install?
Just read your other thread. Did you install 16+ lines with the whoosh adapter again? Or did you buy the 14-15 lines?
PunkST
PunkST
Menasha
I bought 14/15 lines and swapped over. No more adapter as the 14/15 lines are correct for running aftermarket intakes. Plus it has a new valve in it. So that eliminates that as a source i guess. All my parts are cpe. Everything is secure and tight.
My guess is something closer to the tank is goofy. Maybe got hit by an ice chunk and damaged it.
Maybe the rubber line to my hks bov has a leak? Didnt see anything that would make it suspicious. So idk there.
MagnetiseST
Dania Beach
Check the charcoal canister under the spare tire well. That could have a cracked line.
The puzzling one is the air between throttle body and valve. That can only be something leaking at the manifold.
PunkST
PunkST
Menasha
Ok. Only thing that could make a leak there is my MAP adapter and my line for the BOV. I can double check all my connections for the evap setup under the hood. Im fairly positive its all good though as the stuff was brand new.
What Map adapter do you have? If its an ATP ...throw that shit away...they are mediocre at most and get a new one. If you don't Carry on!
MagnetiseST
Dania Beach
Check the connection for the evap line at the manifold. Use carb cleaner or something to see if its leaking. The codes don't make sense. I think the FiST throws the air leak code for other things besides an actual leak.
PunkST
PunkST
Menasha
I can try that. But wouldnt that mean that either the port on the manifold is junk, the new line is also bad ( both of which i doubt) its firmly attached. And i never messed with that connection till i replaced the line itself.
PunkST
PunkST
Menasha
Yes. Double checked this morning. All the fittings are tight.
MagnetiseST
Dania Beach
So I actually figured this one out over the weekend. You have a Turbosmart BOV? My partner had the SAME code for an air leak between throttle body and intake valve. I took his BOV off to clean it and found out that one of the O rings that goes on the vacuum fitting had disintegrated and the fitting itself was loose. So there was a small vacuum leak.
PunkST
PunkST
Menasha
I have the turbosmart MAP adapter. So i have a vacuum source for my hks bov. I can check the map adapter o ring and the line if the codes come back. Knock on wood that they dont. It hasnt done it all weekend.
PunkST
PunkST
Menasha
And they are all back again. Looks like im gonna have to go back to stock or something
