What are some max RPM limits you guys are hitting on builds w/ turbo upgrades?
Working with my tuner now and trying to get a feel for what other guys are doing.
I'm running a Whoosh Hybrid on a COBB stage 3.
Keeping mine stock RPM until I can throw a built motor together.
jeffreylyon
There was a video by DHM where he claimed to be working with Cobb to increase the max RPM supported by the stock ECU to 8500 and had a clip of a FiST pinning its tach. But, then, Russ was apparently pretty good at blowing stuff up.
kivnul
I think mine is capped at 7k. It hits a bit over that in reality. (I try not to look at my needle when I am frantically aiming for cones autocrossing)
Quisp
X47r, 7k, power drops after 6500, but I want a little over rev.
koozy
I'm running Russ' tune with a 7,500 redline. Russ never released the 8,500 redline for public consumption on a stock motor. He advised against it and limited his tunes to 7,500. The 8,500 redline testing was done on his shop car.
@koozy
Was the 7500 rpm on stock cams also?!
Sent from my CLT-L04 using Tapatalk
I am running stock cams....a lot of us are.
koozy
TDavis
Hmm, I'm with Tune+. Wonder if my redline is 7,500. I always shifted at 7k
koozy
During your tuning process data logging for your tuner, you never hit the rev limiter as part of the requirement?
TDavis
Nope, he states to go in 3rd gear from 2500RPM to atleast 6-6500RPM for the datalogs
koozy
It's important to see what's going and how the ECU reacts when bouncing of the rev limiter, especially with aux fuel IMO.
On a side note, it's sad when I see plots with people running GTX's and have the stock rev limit in place. A significant advantage of running GTX's is being able to rev higher without the turbo losing steam.
I talked with Mitch briefly about this. With the built motor and V2 cams/springs, he said he’ll set the rev limit when it stops making power. No sense spinning it beyond that. I said “great now hurry up”! I didn’t
V_2
I'm in the process of tuning aux fuel and my revs are limited by fuel cutoff at 7K with a gt2560r, Tune+.
A
Aux fuel and running out of fuel?
V_2
A
Nah, plenty of fuel to spare. I just meant fuel is being cut to limit revs rather than throttle closure, assuming this is to allow for a potential higher redline if it is deemed beneficial to do so.
Oh you’re still tuning. 4 port?
