WILL IT FIT.....15x7 OZ Ultralegerras
does anyone have experience running 15" rims on a lowered fiesta? I personally have H&R SuperSports. I was considering a 205/50R/15 Azenis rt615k+
I'm almost certain that my 2013 Fiesta had 15" rims but not sure what size tires were on it.
Plainrt
Offset most important thing. Myself and many others have ran 15s lowered no problem
I'm running 15x6et30. I'm using 205/55R15 which is a bit taller then the profile you're looking at. I'll get some rubs on front loaded turns with stock springs.
I'm running 205/55/15 with HR springs , no rubs whatsoever
kevinatfms
15x7 +40mm Sparco Terras with 205/50R15 Federal RS-RR's. Car is lowered with Bilstein B8's and Swift Springs. No rubbing even at speed with one wheel in the air.
If you don't have a big brake kit, yes. They will fit. I am running them now and will post an image tomorrow morning.
neeqness
What shocks are you planning to use with your setup?
Mine on O.Z. Ultraleggera 15X7 with 205/50 R15 Dunlop direzza star spec tires. Stock ST coils on Koni Sport dampers. No fit issues with this setup!
I am not lowered yet, but I run 15x7 Ultraleggeras w/ 205/55-15s and there is definitely room for a drop when the time comes.
13+ lbs lighter, wheel +tire at each corner definitely had benefits.
And they are quiet too.
Same rims, stock susp, but have 205/50-15 Yokos mounted with a slightly reduced tire OD (23.0" vs oem 23.4"). Even though there's lots of room, I thinking about focusing on reducing some body roll without lowering if I can help it. I've had lowered cars and rather avoid the loss of practicality in my DD. That lower plastic piece under the front end already scrapes when leaving/entering my apartment complex.
The lighter rolling stock really magnifies the other upgrades. The only downside is that I do seem to get a lot of negative comments from the bigger is better community regarding the appearance. But, I didn't buy the wheels to be more popular with people who have zero clues about anything.
Ha! I got a little of that and I understand it isn't for everyone... and 16s probably look "better" to many, but I wanted to maximize my weight loss.
I honestly love the extra sidewall... these fill the wheel wells better than I expected them to.
Stock suspension btw
The 15 inch wheel gives it's owner the greatest range of possible ride and handling options regarding the compromises and choices of tires that are available. And at a much more reasonable price than the larger diameter wheel and tire choices. Every time I bolt the original wheel/tire combo back on it, I'm rudely reminded of why they sit in the rack!
