- Member ID
- #7943
- Messages
- 2,609
- Likes
- 2,358
I've found several threads with users slinging "there are threads about this" but I cannot for the life of me locate one with *actual* instructions.
I found a thread listing some differences between the newer and older gen fists, but no actual clear installation instructions. I cannot for the life of me figure out routing the hoses :|
Also, I have been struggling to get the (darn) aluminum intake tube into the (gosh dang) rubber coupler that attach to the (midget farting) turbo. This tube should really be two (goldmine) pieces.
My learnings during install:
- Put the silicone coupler onto the intake before dropping it into the car. If you install the coupler onto the turbo inlet, it's nearly impossible to get the intake pipe in there.
- The heater hose they send is (oxen scat). It either needs a right-angle fitting on the end or tougher, internally supported hose. As-is, it kinks right where it comes out of the intake.
- If you have hand dexterity issues, get help. I paid my neighbor's stick-armed kid a hundred bucks to help me with the really fiddly bits. I just couldn't twist my arms to get an appropriate angle to get the intake seated onto the turbo inlet. It's still not 100% engaged, but its close.
- So far, no matter what I do, it rattles when I start the car and sometimes when I first release the clutch to get moving. Coasting down in-gear causes it to buzz. I currently am on stock mounts, so I will see if it improves with my RMM installed.
- Getting the stock hard-lines off to re-use the fitting (the big one that I think is PCV?) was easy with a blowdryer, I didn't have to cut anything.
- My 2j intake did not come with screws for the MAF sensor. I had to snag the screws from my old Injen intake.
- Because of how it lines up, if you put the MAF sensor in before installing the intake pipe, you run the risk of cracking the maf sensor like I did.
Helpful links:
How to remove the cowl/crossover pipe: https://www.fiestastforum.com/threads/whoosh-motorsports-crossover-pipe-install-and-review.17983/
A (poorly cut) video about the installation:
View: https://www.youtube.com/watch?v=NRlmB0wGjls
I say poorly cut because he cuts out "boring stuff", but that boring stuff is important. Also, bad camera angles. I get that he's trying to make it like a TV show instead of an instructional video, but the angles and presentation get in the way of the efficacy of the video. I'd like to see a "raw uncut" version where he swears for 30 minutes trying to get the intake to line up.
Because of all of my experience with helmholtz and quarter wave noise cancellation, I might add a threaded bung to the side of the 2j intake so I can screw on various sized side-branches to cancel out a few of the more headache-y frequencies from the intake. I would actually like to learn how to custom mold silicone so I can reproduce my 2j in pure silicone, it sure would make installation easier.
Helpful links:
