Coil pack upgrades
New york
Where to find upgraded coil packs for 15’ FiST? I’m not having any luck
Why? You dont need them stock is more than adequate. Go spend your money elsewhere.....besides there aren't any available.
Sean32
New york
I’ve read that high boost levels and OEM coil packs can cause the breaking up or sputtering that I am experiencing. And I don’t want to spend the money on OEM coil packs if I can get aftermarket
What boost are you running? What Turbo? Are their any codes set?
Sean32
New york
I peak around 25psi and I’m on the stock turbo. Only code is for the cat. And a p0455 evap code
What tune? What cat are you running? Or no Cat? What plugs?
Sean32
New york
I’m in the process of getting a custom tune by Jason at DizzyTuning. But I can’t send him WOT logs due to this issue I’m having. And I’m catless. Ngk 11 iridium one step colder plugs. I bought two different sets of plugs to see if it was that but it wasnt
Where they gapped to .026-.028? Why a custom tune on a stock snail? I'd get a flash tune.....did you check compression or leak down?
Sean32
New york
It was a package deal. I got a free e30 custom tune with it. And it builds fine boost. And no I didn’t check compression
Sean32
New york
Was it doing this before you went catless?
No it wasn’t. But it ran fine for about a week or two. The issue started happening after I had to leave somewhere in a hurry and didn’t let the car warm up. Following that day it was doing this ever since
If It was me....I'd go back to catted as the no cat on a stock Turbo gains are negligible....plus you save the barking spiders in the sequoia national forest in Yosemite. Did you use any o2 trickery/ elbow for the the Down stream o2? Did you go the plugs also? Where did you buy them from? Did you use Di-electic grease on the plugs in the boots at all?
Sean32
New york
I have the o2 bung elbow but I never put it in. And I don’t believe the cat would make the my car break up in low rpms on full throttle. Plus I got rid of the cat
Put the elbow in....then contact Jason snd then he will have to send you a file so it tells the o2 what to do. What did you gap the plugs at?
Sean32
New york
Pre-gapped from whoosh motorsports to .027
Did you inspect the plugs before you put them in for possible shipping damage? Cracks in the porcelain? I think you might have a bad fuel pressure sensor possibly also. What's the mileage of the car?
Sean32
New york
Yeah I inspected all of them. Both sets
Sean32
New york
Thread Starter #18
And 65k
