Other trans fluids for refill
PunkST
I know there is the ravenol stuff, and the ford motorcraft. Im wondering if there are others i could pick up at an auto parts store that will sufficiently do the job.
I used a couple different things on my old svt focus ( royal purple synchromesh, and i think deisel engine oil at one point just for grins)
Im trying to make sure i get good life out of the car. And at 80k its probably overdue
If it meets Ford spec for the FiST ....go for it...just remember not to be too frugal. I run the Ravenol 75w80...one of the best and very noticable changes in the fluid area that was immediately felt. Don't forget also...2L not 1.6L when you fill!
Spork1569
Second the ravenol, I changed to the MTF 2 and while I couldn't read the label at all its been a great oil. The fact that the Amazon description says it meets Ford spec as well as the fact it's an actual gear oil instead of DCTF(which the stock fluid is) made it an easy choice.
And like typhoon said immediately noticeable difference from stock. And measuring 2l is super easy as you just buy two bottles and dump em all in.
CanadianGuy
I have been using Royal Purple syncromax for 2 years. No issues super smooth. Throwing it out there as an alternate.
PunkST
PunkST
Cool that i can use synchromax again on this car. I may try the ravenol in the near future. Gonna be under the car this weekend again and remembered it needs doing. Lol. And yes to two liters.
koozy
OE Ford spec factory fill is not gear oil, it is DCTF.
Spork1569
I question a few things Ford does from the factory lol, and I just feel better with gear oil in a manual transmission myself, but to each their own.
I could see the appeal of switching to a better DCTF like motul in order to stay as close to oem as possible.
As long as it meets Ford spec there should be no harm in which you go with.
green_henry
Redline DCTF has been working well for me. I haven't found a store that stocks it, but Summit Racing always has it for a good price
koozy
I could care less what people put in, I just don’t like false information to spread. It does the community no good.
FiSTerMr
That is quality stuff. They now also make a spec'ed gear oil for our trans as well.
2017 Magnetic FiST w/Recaros
danbfree
If you don't understand that meeting EXACT FORD SPEC with Ravenol MTF-2 makes your point moot, sorry bro, but it's not exactly a logical point to keep pushing. It's VERY likely that since they had just came out with those DCT's that they used that for volume pricing and use it up, there is just no logical counter arguing against something that meets exact Ford spec, save the arguments for using random stuff that doesn't meet Ford spec and even then it's likely not a problem as long as it's full synthetic and a known good brand. Now, I will say for those that insist on using DCT fluid, I'd use the Triax SynTrans over factory, it's full synthetic unlike factory, meets Ford spec and as a bonus it's only $16/qt. on Amazon and 2 full qts is still better than the 1.75qts (1.67L) they use at the factory.
danbfree
Right, like trying to argue against using a product that meets EXACTLY the same Ford spec as the factory fill, right? Now THAT is what I would call spreading false information.
danbfree
Nice, I'll have to look into Redline if they have a gear oil that meets spec, really good to hear!
danbfree
The better DCT fluid that actually does meet Ford spec is Triax SynTrans and it's actually full synthetic and cheap as well! I think we all know about the one guy who blames his failed trans on Motul, which doesn't meet Ford spec, but I think that was just a coincidence. For my own peace of mind I'll stick to what meets Ford spec myself, love my Ravenol MTF-2 for now!
danbfree
I found the Redline that meets Ford spec WSS-M2C200-D2 that our trans calls for, it's called MT-LV and even Koozy was the one who first posted it in this forum... However it's only 70w-75, I'm not sure that it would be appropriate for you guys down south in the desert where it hits 115+ degrees, but sound good for where it's mild/colder.
Spork1569
I didn't read about the blown motul transmission till now, guess I'm glad I decided on the ravenol in the end. Like you said it well likely have just been a bad transmission that happened to have motul put into it, but the peace of mind knowing the fluid meets Ford spec is one of the main reasons I ended up with ravenol over other brands.
koozy
I said I don't care what people use. I just stated that what comes delivered in the transmission is DCTF, not gear oil.
Yeah, that is closer to the Ravenol MTF-3 in viscosity. [wink]
It's not even hardly noticeable when its cold here in the winter in Mn....we get really cold sometimes!
