Clutch Fluid Flush procedure
b003k
Planning to flush the brake fluid and knowing the clutch system uses a secondary reservoir that pulls from the brake master cylinder reservoir, I was hoping someone could provide insight on how to flush the clutch fluid.
I know there's a bleed nipple near the transmission?
I basically need clarification on the procedure to flush it. For example, do I top the master reservoir and then open the clutch bleed?
Or do I top up the secondary reservoir and then open the clutch bleed?
Also should i flush clutch first then brakes? or brakes then clutch?
Quisp
The bleeder for the clutch has a plastic lever you open to let out fluid. I did the brakes first, but I don't see any advantages to either sequence.
Quisp, did the airbox and battery have to come out to access the bleeder?
Thanks, I'll have a gander.
Edit - Found it - airbox only it seems. Great! Thanks!
SST
If you do a search, krug replied to a thread of mine with the procedure, with pics and everything.
I search all threads under your name and can't find it, can you share the link please?
FiestaSTdude
I second this request
