Just wanted to post up on my experience today getting my 225/50/16 re71r's to fit. They are mounted up on some konig dekagram 16×8 (et40 I believe). It took me about 4 hours of fiddling and test driving to get the rub to go away. Im on godspeed monoss coilovers and I had to max out the rear for height and get pretty close to maxing out the fronts. Im at neutral camber all around currently and a 2 finger gap is enough clearance on fully preloaded springs to keep the fender from rubbing the sidewalls. I had to cut a bunch of clearance out of my rokblokz mudflaps in the front to keep the wheels from rubbing on them when turned all the way either direction. Some things I plan on doing soon is -1 degree camber all around and rolling the fenders so I can drop the fronts to match the rears without rubbing. I should have gone 225/45/16 to avoid most of my issues but I didnt do enough research and I quite like the meaty look. For anyone looking into thise size - its doable but prepare to spend a while to get them to fit.
