So I dropped my car off yesterday to a well regarded nearby mechanic to replace the front pads and rotors. I went with centric cryogenic blanks and mountune street pads. Being that the car is modified and I wasn't using OEM parts I didn't want to use the dealership. Also I have done 90% of the mods on my car but brakes I wanted to leave to a "Pro". Well 4 hours later I talk with the mechanic and he says the front calipers are stuck.
He had put the replacement parts on, swapped back to the stock parts, bled the brake system 3 times, but nothing would fix the problem. He knew about the pads being outside and inside specific. The front brakes won't retract, making the car not drivable. When we turn on the car the screen says "Hill start assist not available". That is the only clue. No ABS lights or any warning lights on the dash. So maybe the HSA is engaging for some weird reason??!! My only idea is to disconnect the battery and see if that resets something. If he can't fix it I will flash the car back to stock and get it towed to the dealership. I am not about to flatspot my brand new Indy 500's driving it with locked brakes. Ughh, what a nightmare. Any help or tips are welcome. Thanks guys.
